Smart Bluetooth
            I need the solution for floating point support for BCM20737S
           When I declare a float variable(in global) for example (float id=10.5;)It showing the following error "undefined reference to `__aeabi_f2uiz'" in WICED smart ide2.2.1. at the same time when i declare the float variable in Local It not showing error but it print the output in terminal only "ffffffffff" instead of 10.5. For printing i used the following method. ble_trace1("Out:%f\n",id); please give me the exact solution for print and access of float variable.
Hello Ripit,
The floating point data types are NOT supported.
You must use fixed point library.
JT
As per your reply i tested all three reference , but all the reference are not support  the float variable deceleration and serial print option. Again i got the same result what i mentioned previous our conversation, please give me exact example for float variable access. If suppose BCM20737s not support for FPU  then please inform us,
Hello Ripit,
Let us check with the developers on this request.
JT
Please reply us soon as possible
Hello Ripit,
JT
Already we tried with libfixmath.a library its not giving correct output, please share small example with fixed point library. Please send the output also(with float ).
MichaelF_56
Floating point data types are NOT supported.
