I tried to re-build the tool chain in WICED Smart SDK 2.2.0 but failed finally.
Below is the details.
1, Go to directory at \Tools\source\ARM_GNU
2, According to the instruction in README.TXT I
2.1) installed MinGW and necessary components
2.2) Downloaded all needed source code and place under directory \download.
3, Open MinGW shell and type command "xx-build-all.sh".
4, The build process seems to be successful from "01-build-expat.sh" to "07-build-newlib.sh".
I also can see the output file "#-ready.txt" (#=01, 02, ..., 07).
5, But build process stopped when building "08-build-gcc.sh".
Below is the error log.
My questions:
Question #1: How to solve this issue?
Question #2: If the build succeed finally, can i replace the old tool chain files under directory \Tools\ARM_GNU with the newly generated files?
In fact, my purpose is try to re-build the tool chain with new version of newlib (e.g. 2.2.0) which may have a good support for soft float point math ^_^
thanks a lot.
SDK 2.X
Unfortunately, we cannot support rebuilding of the tool chain.
As I noted previously, we are working on the public release of an installer based version of SDK 2.2 for Ubuntu Linux.
Any one can help on this?
thanks a lot.
thanks a lot.
