TiHu_1708166
Welcome! First question asked First reply posted
We have a project using BCM20713, and we found it seems can only send 3 27 bytes packets for every connection interval. Is there any Vendor Specific Command can adjust the maximum number of packets? Thanks.
MichaelF_56
Unfortunately, the CYW20713 is not an broad market device, and as such, is not supported here on the IoT community.
Please reach out to the Cypress sales/distribution team that enabled you on this device and ask them to setup a direct channel for support for the factory.
MichaelF_56
Hi mifo,
Then, can you advise where I can get tech support for CYW20713? Thank you very much.
Like MIFO said, you will have to get in touch with your local Cypress Sales / Distribution. They will in turn get you help on this device.
Winston
