Smart Bluetooth
it is possible to add or delete a BLE characteristic in run-time?
Armando
JacobT_81
You won't be able to alter a single characteristic within an initialized GATT db. What you can do is have an entire second GATT db with the changes made and switch between the two dynamically. See the post here for a sample app of this action: How to change the GATT database after init (bleapp_set_cfg) ?
Jacob
JacobT_81
Jacob
