I wanted to use BCM92073X_LE_KIT with I2C controlled OLED display and SPI/I2C driven Murata ZPA Series MEMS Barometric Pressure Sensors
Since I need to use two I2C ports in my design (one for OLED and other for pressure sensor) , I just wanted to confirm can I use BCM92073X_LE_KIT to connect two I2C slave devices? Can you please share the BCM92073X_LE_KIT technical reference manual?
Moving to the Bluetooth forum.
The Hardware User Guide is here: Hardware User Guide (SDK 2.x and TAG3 Board)
You will also want to familiarize yourself with the WICED™ Smart Hardware Interfaces
Yes, WICED Sense leverages the I2C bus to connecte multiple sensors to the BCM20737S SiP module.
Full source code for WICED Sense is available here on the forum: WICED Sense Table of Contents
