BCM20737S firmware/bootloader recovery
During downloading of my software on BCM20737S module,  Power goes out. So firmware downloading fails.
Now  development environment recognizes module, but it is impossibile to download firmware on module.
Is there a possibilities to recover BCM20737S module?
Thanks in advance,
Vittorio
MichaelF_56
If you are developing using the Broadcom TAG board, then the recovery process is outlined in the WICED Smart Quick Start Guide (SDK 2.x and TAG3 Board)
If a custom board, using the 20737S module, there are numerous threads on the subject.
Here's a few of the better ones:
BCM20737S recovery problems
Unable to (re) program BCM20736
Programming the TAG2/TAG3 Board using command line tools
Re: 20732S-Recovery from FW download failure
elanoy ehoffman jose.raffucci
In my experience, interrupting a download in progress almost always results in the need to recover.  I'm not sure what made your "power goes out" condition, but you should try to avoid that if at all possible.  A number of things can make recovery challenging, so if you have trouble, let us know.
Eric
BoonT_56
So did you manage to recover your board?
vittorio.loggia
Apparently yes,
