Good afternoon
I need to have a two scenario usage with the BCM2073xS module regarding I2C behavior:
- i2C master to discuss with I2C devices
- disconnected i2c port because an another device will be the master.
As BCM2073xS doesn't support I2C multimaster, do you know if it is possible to desactivate I2C master port after booting (for example at the beginning of the application) ? (if no access to E2PROM are required after the boot process).
thank you
best regards
I2C
Hello E L
1. EEPROM in internal to module - therefore not possible at this time.
2. Cannot store Link Keys and access is limited to EEPROM
JT
We will talk to the developers this week to see what's needed to essentially deactivate the I2C port once the part boots and moves the application image to RAM.
Hello E L
JT
