Smart Bluetooth
In the document "BCM2073X Product Portfolio", it says that BCM20737 chip has NFC paring. Is there any documentation on this? Does that mean BCM20737 has both BLE and NFC capability?
I can't find any info on the BCM20737 chip.
-Mehrdad
MichaelF_56
The 20737/20737S will support an NFC tag waking up the BCM20737 over GPIO when a reader reads from the NFC tag. It then sends the information received over GPIO from the NFC tag through a BT link (acts as an interpreter). You still need an NFC Tag and Reader within the application. This feature also cannot be used for OOB pairing.
MichaelF_56
