In the document "BCM2073X Product Portfolio", it says that BCM20737 chip has NFC paring. Is there any documentation on this? Does that mean BCM20737 has both BLE and NFC capability?
I can't find any info on the BCM20737 chip.
-Mehrdad
The 20737/20737S will support an NFC tag waking up the BCM20737 over GPIO when a reader reads from the NFC tag. It then sends the information received over GPIO from the NFC tag through a BT link (acts as an interpreter). You still need an NFC Tag and Reader within the application. This feature also cannot be used for OOB pairing.
