Smart Bluetooth
Hi we are working on a security access control project where we are trying to use BCM20736 device.
to finalize on the chipset we want the below data.
DetailsBCM20736
Vendor support
Road map
EOL data
Test and Qualification data
Future upgrade
Backward compatibility
Debugging capability
Volume Pricing
Volume shipments
Stability of Chipset in
  market
MichaelF_56
The BCM20736 was just introduced near the end of last year.  There is no EOL planned.
This part is pin and source code compatible with the 20732, and pin and firmware compatible with the 20737.
Debugging is discussed in great detail here on the forum.  There is no JTAG capability on this part.
Many of the other questions asked could be addressed by one of your local Distributors
MichaelF_56
