Any document for defining the packet format in advertising event?
We can see samples from hello_sensor.c and also the parsing function inside blecen.c.
But do we have document for definition of all these packet format?
Hello dunk.chen,
The definitions of the advertisement types are available at:
https://www.bluetooth.org/en-us/specification/assigned-numbers/generic-access-profile
The Core 4.1 Spec Section 2.3 ADVERTISING CHANNEL PDU (Page 2504/2684) also lists the details of the Advertising PDU's and the Flags field.
Does this answer your question?
JT
MichaelF_56
Advertisement packets are sent on 3 channels which include 37, 38, and 39; these channels are 2.402GHz, 2.426GHz, and 2.480GHz respectively.
Four types of advertising events can be used, with each advertising event type having different sized advertising packets. These advertising packets can vary in length from 8 to 39 octets.
The basic format of a BLE packet looks like this:
The best place to obtain more detailed information is via the Bluetooth spec, which is available online here: Bluetooth Core Specification Version 4.0
Sorry that if I don't put question specifically.
From blecen.c, the function 'blecen_AdvDataParse' do some specific parsing from the advertising event.
Is there document for defining the format of these packet type, i.e. ADV_FLAGS, ADV_SERVICE_UUID16_COMP?
Thanks in advance.
Hello dunk.chen,
JT
Hi JT,
  Great thanks for this.
  This did answer my question.
