Smart Bluetooth
MiTo_1583836
Contributor II
I am reviewing the WICED environment, especially the pre-compiled libraries (*.a) for Bluetooth and Wi-Fi products.
I see for example:
/Library/bluetooth/internal/stack/LE/Lib_Bluetooth_LE_Stack.ThreadX.ARM_Cortex_M3.debug.a
or
/Wiced/Network/NetX/NetX.ARM_Cortex_M3.debug.a
Is there a way to have access to the source code of these libraries? Is there a specific agreement that can be put in place with Broadcom to access the source code that has been used to generate the libraries?
MichaelF_56
Our BLE stack is in ROM and not available as source.
I don't know about Bluetooth library.
About NetX, it's a commercial product and royalty is required normally.
So in order to use it free by WICED customer, it needs to be provided as a binary image.
If you would like to have source code, you can choose FreeRTOS/LwIP.
MiTo_1583836
Contributor II
Ok thanks, let's see if someone can comment on the Bluetooth stack.
MichaelF_56
