Smart Bluetooth
Is there any readily available trap handler for application debugging purpose?
For example, if application triggers a 'trap handler' or 'hard fault handler' on ASSERT failure,
the trap handler in low level firmware prints out ARM register/stack dump through UART and halts running.
I want to check if there is readily available low level trap handler before
starting implementation of our own in application layer.
This question is regarding 20737 BLE processor.
Thanks in advance
ArvindS_76
No, there are no hooks in any of the trap handlers.
ArvindS_76
