30ms Active Low Pulse not recognized in GPIO Interrupt Falling Edge
I am using AIR_GPIO_RegisterInterrupt(13, myCallBackFunc13, AIR_GPIO_TRIGGER_FALLING_EDGE );
and
void myCallBackFunc13() {
        iWasInturrupted = 13;
        AIR_BLE_SetDiscoverable(true);
now my interrupt pulse is  active low  but only for about 20-30 ms.  I am unable to reconnect the BLE in time to send the event trigger data.
Does anyone know how long the AIR_BLE_SetDiscoverable(true) should be true for it to be sufficient to sent this info.
I was hoping the easiest solution would be to add a delay in the myCallBackFunc13 to ensure there is enough time to do this.
Anyone experience anything like this? Any other software workaround to ensure this works smoothly? I guess because i designed the BLE device to be off always but for the interrupt times to save battery is the issue.
Hello Kava,
What example are you using from the SDK?
JT
This is from Anaren Air Atmosphere.based of the Broadcom SIP.
Thanks mwf_mmfae
I replied to your post on the Anaren Atmosphere forum.
Mininmum time GPIO intterupt needed to reconnect BLE | Anaren Atmosphere
