Smart Bluetooth
Compared with fine timer, the BT clock timer have higher resolution and seem to consume less power.
My question:
Is it suggested to use BT clock timer instead of fine timer wherever possible?
Is there any side effect?
thanks a lot!
Hello Roger,
Fine Timer 12.5ms - This is the preferred method
BT Clock Timer - 1.25ms - More power consuming and may effect Bluetooth connection.
Hello Roger,
understand. thanks a lot.
