SRAM
CoraZhang
5 questions asked 5 sign-ins First reply posted
Dear Sir/Madam,
GreenSoft Technology, a leading provider of environmental compliance data management services and software for the global electronics industry (http://www.greensofttech.com), has been contracted by Nortek to collect compliance data on parts purchased from your company.
Please note that Nortek might not purchase directly from your company but via a reseller or distributor. In addition, you may need to collect material or compliance documents from your suppliers to fulfill this request. Your support to Nortek is highly appreciated.
One of your parts that they are requesting data for is:
      P/N: CY62136EV30LL-45ZSXI
      Description: IC, SRAM, 2MBIT, 128K X 16, 45NS, TSOP-44
P/N: CY62157EV30LL-45BVXI
      Description: IC, SRAM, 8MBIT, 512K X 16, 45NS, FBGA-48 (6X8MM)
P/N: CY8C27443-24PVXIT
      Description: IC, CY8C27443-PVXIT, MCU, 16KB, SSOP-28
P/N: CY8C29666-24PVXI
      Description: IC, CY8C29666-24PVXIT, MCU, 32KB, SSOP-48
P/N: S29AL008J55BFIR22
      Description: IC, FLASH, 8MBIT (1MB X 8 / 512K X 16), 70NS MAX, FBGA-48 (6X8MM)
Can you please provide the following environmental compliance data for this part:
  • REACH Declaration or SVHC Certificate. If a product contains any SVHC or Substances of REACH - Annex XIV, please provide the substance name and concentration, as well as future plan to eliminate its use.
  • If reportable SVHCs are identified, please provide the SCIP data (SCIP – per Waste Framework Directive 2008/98/EC, amended by Directive (EU) 2018/851)
  • Full Material Disclosure (FMD), MSDS or similar document in your standard format if available
  • CA Prop65 Certificate of Compliance (CoC); a template is attached.
Generally, the parts applicable for 6a/6b/6c RoHS alloy exemptions would form an article, such as a pin, connector shell, standoff, screw, or bracket. Therefore, Lead concentration of such parts is likely to exceed 1000ppm at Article level, which needs your further support to provide the SCIP information. However, if you confirm your products are SVHC compliant, please provide the Article Name.
If you cannot recognize a part or it’s incorrect, please indicate such in your feedback.
Please respond as soon as possible or provide an expected date of completion and we will follow up. We may contact you if any clarification is needed. Nortek is committed to providing its customers with products that meet the highest standards of innovation, performance and environmental safety and expects your timely response
If you have any questions, you can contact me at Cora@greensoft-china.com or call +1 323-254-5961 x813 (I am based in China; we also have someone in our US office that can answer your questions).
Cora Zhang
Project Engineer
GreenSoft Technology, Inc.
155 S. El Molino Ave, Suite 100,
Pasadena, CA 91101, USA
Ph: 323.254.5961
GreenSoft Technology – China Office
No 368, North Xinshi Rd, FL12
Shijiazhuang,Hebei, China
Ph: +86-311-8386-4638
ritwicksharma
Moderator First question asked 100 sign-ins 50 replies posted
Hi @CoraZhang ,
Kindly create mycase of "Quality Documentation" type for required data for the above-mentioned parts.
Ritwick
