Need corrected data sheet for the CY7C1062GE sram. Data sheet has Vcc and Ground, but pinouts only have Vss and Vdd.
Hi Chuck,
The VDD corresponds to VCC and Ground corresponds to VSS, since it is not uniform in the datasheet, we will get the datasheet updated on the website. Allow us some time for the changes. All other specifications like the AC and DC specs are correct and you can use them.
Pradipta.
