- Email to a Friend
Hello all.
I have a trouble with driver for BGT60LTR11AIP. please Do you a lowLevel driver for radar chip? The best for me is simple driver in C language. My Hw contain ARM cortexm0+ (STM32).
Than you for help
Jaromir
- Email to a Friend
Hello @Jaromir
You can then only use the "Autonomous" BGT60LTR11AIP Shield, where you can use potentiometers to change the sensor configuration (threshold, holdtime). With the autonomous shield you can get a detection range between [0.5-7]m.
If you have already the DEMO BGT60LTR11AIP board, you can use the offred Python wrapper to change the sensor configuration and to get the detection status.
Hope that helps.
Cheers,
Montassar.
- Email to a Friend
Hi @Jaromir,
Please download the BGT60LTR11AIP package from Infineon Developer Center and the communication library is available for demo kit in the package (Radar BGT60LTR11AIP\2.8.1.202111260850\application\BGT60LTR11AIP-DOC-HW-SW\BGT60LTR11AIP-DOC-HW-SW_V2.8.1\SW) for python and Matlab.
I am really sorry to inform that C communication library is not available for BGT60LTR11AIP.
Thanks and regards
George
- Email to a Friend
Hello George
I hope that driver exits for SAMD controller. the development board contain cortexM7 and radar chip. complete radar setting is done by SAMD controller
Jaromir
- Email to a Friend
Hi @Jaromir,
If you use the BGT60LTR11AIP "Autonomous mode", you will get directly the output of the radar sensor to indicate if a target is detected (TDet), and also the direction of motion of a detected target (PDet). Thus, you do not need any SPI low-level driver for the BGT60LTR11AIP.
Did you really need to enable the "SPI mode" ? What's your target application?
Montassar.
- Email to a Friend
Hello Montassar
My target application is home automation. I have to change the range of radar characteristic in initial sequence depends on user setting. the setting will be done either by potentiometer or by mobile app. the range will be 10cm for touchless switching or from 4 to 8 meters in case of presence detector.
Jaromir
- Email to a Friend
Hello @Jaromir
Hope that helps.
Cheers,
Montassar.
- Email to a Friend
Hello @Jaromir,
As @Montassar-BR suggested you can use the shield in autonomous mode for your application.
Please refer to the application note AN608 (section-5, page-19 onwards) for changing the shield to autonomous mode and the resistor settings required for different detection ranges and hold times.
George
- Email to a Friend
