Public Archive
Is there updates any for 32nm flash drivers for linux 3.14 . Actually we are facing problem of  NAND read from uboot.
Uday
GernotH_31
Hi Uday,
these devices should work fine, under both u-boot and Linux.
We need more information about the problem in order to help you.
What is the exact device type (OPN)? What does the boot messages look like?
How does the failure exactly look like?
You might also want to open a technical support case to track this.
Gernot
GernotH_31
Hi Uday,
Gernot
