Public Archive
We replaced Micron P/N MT29F8G08ABACAH4-ITS:C with Cypress P/N S34ML08G201BHV000.  We believe it to be a near direct drop in  replacement but we are unable to talk with the Cypress part.  Where can I find a detailed timing diagram for S34ML08G201BHV000 so I can compare it to the Micron part?
AS_36
Hi Daniel,
S34ML08G2 is dual die stack of two S34ML04G2. For the detailed specifications you can refer to the datasheet of S34ML04G2.
Here is the link to the datasheet - http://www.cypress.com/file/218306/download
Thanks and Regards,
Apurva
AS_36
Hi Daniel,
Thanks and Regards,
Apurva
