how to calculate the quiescent current of TLS810B1EJV50 voltage regulator.
in simulation model we are able to measure output voltage but we not able measure output load current this ic.
Thank you for posting in Infineon community,
Please refer sec 5.3 Current consumption of datasheet to know the quiescent current of TLS810B1EJV50 under various boundary conditions.
To measure output current, place a load resistor (>50ohm) at the output pin and measure the current through it.
Anil
Anil
