Hi, Can any suggest the Most Popular Analog CCM PFC IC from Infineon. I have external Aux supply to start IC. Power Range - 1KW to 2.4KW. My LLC is IC is having Brownout Protection and PFC Disable Function @ Light load. So for PFC no need of Brownout Protection but PFC disable at light load is preferable.
Power Management
- CCM PFC
Hello Ashok,
Thank You for posting your query in the Infineon community.
Widely used CCM PFC for the mentioned power ratings (1kW to 2.4kW) are 3rd Generation PFC-CCM controllers,
- ICE3PCS01G (wide power range design references are available for this IC)
- ICE3PCS02G
- ICE3PCS03G
The key benefits of this controllers are,
- Integrated digital voltage loop compensation
- External synchronization (50kHz~100kHz)
- Separate signal & power ground pins (ICE3PCS01G).
- Proven design reference with advance GaN technology is available (ICE3PCS01G).
Please find the below link for the reference design,
https://www.infineon.com/cms/en/product/evaluation-boards/eval_2500w_pfc_gan_a/
Please contact local FAE for the Leadtime details.
Premsagar S
Hi Premsagar, thanks for reply. Can you please send details of FAE who is taking care of Hyderabad region to mail id ashokchakravarthi@chargehouse.in
