Hi Team ,
We wanted Design with IR38164 below requirement
Input 12V and Output - 5V : 15A Typical and Peak current 25A , Data sheet Mentions Output can be set through resistor Divider on Feedback pin or PMBUS.
Could please provide more details on Setting VOUT =5V on Resistor Divider and also on compensation values.
Uday
Power Management
Hi @udaykumar
Thank you for contributing to the Infineon community.
Please use the table below for setting the output voltage according to the mode of operation.
Ensure that you match the ratio as shown below while selecting the feedback resistors for analog mode.
Ensure that you match the ratio as shown below while selecting the feedback resistors for Digital mode.
Feedback loop compensation is achieved by Voltage Mode control using standard Type III techniques. Refer to the application note in the below link for the complete compensation design.
Kindly let me know if you have any further queries.
Nishanth
Hi @udaykumar
Nishanth
