newlib syscall stubs
RaAl_264636
Level 6
Level 6
50 sign-ins 25 sign-ins 10 solutions authored
I want to realize the newlib syscall stubs. I know that they're delivered pre-compiled, but if own implementations are provided, those implementations will be used.
Has anyone experience with implementing those stubs? The newlib documentation https://sourceware.org/newlib/libc.html#Syscalls shows the minimum implementations. However, if I use them as a base without modification, some errors are thrown. For example, the sbrk() function uses 'stack_ptr', but it's not stated where this variable is defined. Do I have to replace this with the stack pointer for the target device, register R13 in case of Cortex-M processors?
So, the question is how to implement the stubs correctly for PSoC.
Ralf
JobinT_31
50 solutions authored 25 solutions authored 10 solutions authored
Hi Ralf,
You will be able to find some information in these below links. I don't think any one here have done this already:
https://www.gnu.org/software/libc/manual/html_node/Porting.html
http://forum.osdev.org/viewtopic.php?t=27073&p=226666
JOBIN GT
JobinT_31
Hi Ralf,
JOBIN GT
RaAl_264636
Level 6
Level 6
Hi Jobin,
thank you for those links, I'll read through them.
Ralf
