PSoC™ Creator & Designer
hi every one ^^
i try to calculate the frequency of an input Pulse signal, sow i add a counter, the signal that i want to measure is a signal 200hz, 5ms, sow i add a clock 24mhz and try to count every 1mz for having the numer of impulse on
dont khnow why it dosnt work, need some help
thank u
rola_264706
Honored Contributor II
Here is a frequency counter using PSOC ble. It should give you some ideals on what you are doing wrong.
  • her the count that i use
rola_264706
Check this document
rola_264706
ok am not using ble but it will be interresting, thank you ^^
her my laste test that i done juste 30min befor, and i wish if you can take a look 🙂
i obtain a value with this code 🙂
