I am having issues with PSoC designer while compiling a project. Up till yesterday everything was working fine however since this morning compling a project is taking anywhere from 5 to 10 minutes. This used to take about 20 seconds. I have tried restarting the computer and also i uninstalled the designer and reinstalled it again. The problem still exists.
I also noticed that everytime i try to restart or shut off the computer i get and error: CMXPD - System can not end this program because it is waiting for a response from you.
Not sure what is going ond and why it is taking this long to compile a project.
Any help would be greatly appreciated.
Arun
TeHe_281121
Hi Arun,
Sounds like a general PC/windows problem. You may want to bring up your task manager to see what is hogging your system. Look at the CPU usage in the Performace tab, and the Processes tab (sorted by CPU usage) to help track it down.
Generally a scheduled anti-virus scan or disk defrag is th culprit.
Hope this helps.
