Jul 25, 2018
01:19 AM
Jul 25, 2018
01:19 AM
I'm using Psoc Creator 3.3_SP2. It takes almost 15 minutes to enter debug mode every time. Every project ! Every time!
Psoc Creator is installed on C disk and other modules in the software don't have this phenomenon.
I can' understand why....and this problem seriously affects my work efficiency. Could you help me, please?
Thank you very much.
03:05 AM
Jul 25, 2018
03:05 AM
Creator 3.3 is a bit outdated. I would suggest to try Creator 4.2 (actual version). Update for some components will be required, I2C APIs have changed.
Check if you have network connections which (when invalid) can increase access times dramatically.
Check the PATH environment for invalid entries.
Bob
