PSoC™ Creator & Designer
        Using UART transmites INT type datum ,the datum must be ASCII type ,how to transform into datum of INT type when recieving?
pushekm_21
        As i have understood then you want to transmit data in the ascii format. For this you have to convert the number into a ascii data before sending. The ascii data can be stored as a char array and then trasnmitted.
