PSoC™ Creator & Designer
ETRO_SSN583
Esteemed Contributor
Why will this simple switch typing not work ? Project attached.
Note the first error goes away in the switch construct if I eliminate "case 4 :"
Regards, Dana.
Bob_Marlowe
Expert II
There is a semicolon missing after the colon of case 4
there is a "}" missing at the end to close the main()
Happy coding
Bob
Bob_Marlowe
Expert II
Happy coding
Bob
ETRO_SSN583
Thanks Bob, feel like idiot missing the for() terminating bracket.
Did not realize a CASE statement had to have code following it. If I place a break;
after last case that error goes away.
Regards, Dana.
