It does not work to press ctrl + E, C/ ctrl + E, U in PSoC Creator 3.3
Anybody can tell me what's happening?
Thank you!
Bob_Marlowe
Level 10
Level 10
Right click into the menu-area of creator. Last entry of the context-menu is the customizer..
When you go into Creator's Help you may search for "keyboard shortcuts" and there are some more instructions.
Bob
Bob_Marlowe
Level 10
Level 10
I deleted the shortcut in customize dialog and created it new, now it works.
Bob
Thank you!
Can you tell me how to do that? I did not find the customize dialog you mentioned
Bob_Marlowe
Level 10
Level 10
Bob
Thank you!
I found the shortcut in Edit, and it told me the Key "ctrl + C, E" is protected and cannot be removed.
However, I successfully assigned new shortcut in C/C++ editor instead of global and now it works.
Sen
Bob_Marlowe
Level 10
Level 10
Congratulations!
When your other problem gets solved, too your working with PSoCs will not be hindered any more.
Bob
JoBr_1593366
100 sign-ins 50 questions asked 100 replies posted
What does "Ctrl + E, C" even mean?  Press Ctrl+E+C?  Press Ctrl+E, then let go, then press C?  Hold down Ctrl, Press E, press C, and then let go of Ctrl?  None of these work for me.
Bob_Marlowe
Level 10
Level 10
Press Ctrl+e, then let go, then press c
At least, this works for me.
Bob
Thanks, Bob, it worked for me as well. I solved my issue.
Now I can continue working a  ## with no difficulties.
