IMPORTANT: Cypress Developer Community currently doesn’t allow sign-in to prepare for the upcoming transition. To learn more, check out our announcement.
PSoC™ Creator & Designer
ZoVa_4661926
New Contributor
I can not type simple '|' (pipeline) character in the code editor.
I think the reason is in Hungary it is on the AlrGr+W (Ctrl+Alt+W) combination and that is a shortcut in the PSoC Creator.
But I can't remove shortcut.
Is there any solution to solve this barrier.
2020-03-12 13_01_06-A2B_Switch_FW_003 - PSoC Creator 4.3  [C__..._Hardware_A2B switch_A2B_Switch_FW_.png
Rakshith
Hi zova_4661926​,
Ctrl+Alt+W is actually used by WatchMenu.2, WatchMenu.3 and WatchMenu.4 as shown -
Please remove these shortcuts by clicking on Remove button and then you can assign it to any other shortcut you want as shown -
Hope this helps,
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Rakshith
Hi zova_4661926​,
Hope this helps,
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
ZoVa_4661926
New Contributor
I've removed from all 'WatchMenu' and now it's working as I like.
Thanks!
Rakshith
Glad your issue is resolved
Rakshith
Thanks and Regards,
Rakshith M B
