Does the PSoC Creator allow for reading the image in a device (cy7c64215) and have any ability to dis-assemble the code?
You can use PSoC Programmer to read flash from the encore III device. Please download PSoC Programmer GUI from the link below. Also, please refer PSoC programmer user guide.
https://www.cypress.com/documentation/software-and-drivers/psoc-programmer-archive
https://www.cypress.com/documentation/other-resources/psoc-programmer-user-guide
To read flash from the PSoC Programmer GUI, you need Miniprog 3 device and also one connector as below:
https://www.cypress.com/documentation/other-resources/cy3655-plg
Hope the above information helps ! Else, please reply.
Ganesh
Ganesh
Please go through the following KBA for other programming options.
Can I program enCoRe III through the USB connector just like enCoRe II?
Ganesh
