PSoC™ Creator & Designer
ETRO_SSN583
Esteemed Contributor
Build this into Designer as a tool, takes 2 R's and user has a
level translator w/o using a PGA and/or a fixed reference to do it.
Do not just incorporate the attached, build it into the IDE, and select
from standard R 1% values and compute worst case.
Regards, Dana.
Dana, do you think this is more appropriate for Designer or Creator? I saw you proposed this change for both tools.
