Hello everyone,
I have a question regarding the heart sensor. I saw this topic on the internet:
I took thist project:
and saw the following code:
- First, I didn't understand what this interruption does.
- Second, in the part "bpm = 60000 / beat;", I understood that it would be how many pulses he gave 60000 milliseconds divided by the amount of pulses he gave in that time, however in the part "beat = ADC_GetResult16 (0);" does it take the amount of pulses in 60000 milliseconds? I didn't get it right.
PSoC Creator & Designer Software
- psoc 4
RoFr,
The interrupt is attached to the ADC. When the ADC completes a conversion, then the interrupt gets executed.
In the interrupt, the source of the interrupt is cleared and a flag (n=1) gets sent to the main() task to signal the ADC needs processing.
About 2.: Not sure. The ADC reads the instantaneous voltage of the sensor through a low-pass filter and then a Difference amp configuration(?). One would think you'd want the number of beats in 60000ms (60 seconds).
Maybe you should ask the author of the project.
RoFr,
