PSoC™ Creator & Designer
Hi everyone, i have a cy8c4125pvi-482 microcontroller and use “Psoc Programmer 3.23 version” to program it, but in Psoc Programmer 3.26 version, cy8c4125pvi-482 does not exist, and other micro that i used is CY8C4025AZI-S413. The CY8C4025AZI-S413 exists in 3.26 and does not exist in 3.23 so i always change the version of programmer. Can you help me about how to program thi micros in same program?
Roy_Liu
CY8C4125PVI-482 should exist in Programmer 3.26. How did you identify it does not exist?
Roy Liu
Roy_Liu
Roy Liu
No it does not, can you show me with a ss?
Thanks, i found it, i actually had a diffrent problem and solved it, thanks again
