DaHu_285096
10 likes received 250 replies posted 100 replies posted
I have just started using the ultralight cJSON files from Dave Gamble's git ().
GitHub - DaveGamble/cJSON: Ultralightweight JSON parser in ANSI C
I have no issue serializing and parsing strings but there is some issue with the adding numbers to the object. Has anyone else had this issue and know what is happening?
In my code I create several string value pairs no issue like this
cJSON *payload_json = CJSON_CreateObject();
CJSON_AddNumberToObject(payload_json, "range",n);
I have tried numeric variable and fixed number. The object ends up with blank instead of number like { "range":      }
If I use say CJSON_AddStringToObject(payload_json,"result","ok"); I get correct packet {"result":"ok"}
Rakshith
Moderator 1000 replies posted 750 replies posted 500 replies posted
Hi DaHu_285096​,
I have not used the JSON parser that you are referring to. But I found these issues created in the repo that might help you -
  1. Limiting print decimal point
  2. cJSON does not work on non-ASCII systems
Hope this helps,
Thanks and Regards,
Rakshith
Thanks and Regards,
Rakshith M B
Rakshith
Hi DaHu_285096​,
Hope this helps,
Thanks and Regards,
Rakshith
Thanks and Regards,
Rakshith M B
