--------------- Rebuild Started: 03/02/2016 10:11:33 Project: PRoC_BLE_CapSense_Slider_LED, Configuration: ARM GCC 4.9-2015-q1-update Debug ---------------
Deleting file ".\PRoC_BLE_CapSense_Slider_LED.cycdx"
Deleting file ".\PRoC_BLE_CapSense_Slider_LED.svd"
Deleting file ".\PRoC_BLE_CapSense_Slider_LED.rpt"
Deleting file ".\PRoC_BLE_CapSense_Slider_LED_timing.html"
cydsfit.exe -.appdatapath "C:\Users\BobOld\AppData\Local\Cypress Semiconductor\PSoC Creator\3.3" -.fdsnotice -.fdswarpdepfile=warp_dependencies.txt -.fdselabdepfile=elab_dependencies.txt -.fdsbldfile=generated_files.txt -p "C:\Users\BobOld\Desktop\PSoc Creator\PRoC_BLE_CapSense_Slider_LED\PRoC_BLE_CapSense_Slider_LED.cydsn\PRoC_BLE_CapSense_Slider_LED.cyprj" -d CYBL10563-56LQXI -s "C:\Users\BobOld\Desktop\PSoc Creator\PRoC_BLE_CapSense_Slider_LED\PRoC_BLE_CapSense_Slider_LED.cydsn\Generated_Source\PSoC4" -- -yv2 -q10 -ygs -o2 -v3 -.fftcfgtype=LE
Elaborating Design...
HDL Generation ...
Synthesis ...
Place and Route ...
Tech mapping ...
Analog Placement ...
Analog Routing ...
Analog Code Generation ...
Digital Placement ...
Digital Routing ...
Bitstream Generation ...
Static timing analysis ...
API Generation ...
Dependency Generation ...
Clean Temporary Files ...
arm-none-eabi-gcc.exe -mcpu=cortex-m0 -mthumb -Wno-main -I. -IGenerated_Source\PSoC4 -Wa,-alh=.\CortexM0\ARM_GCC_493\Debug/main.lst -g -D DEBUG -Wall -ffunction-sections -O0 -ffat-lto-objects -c .\main.c -o .\CortexM0\ARM_GCC_493\Debug\main.o
arm-none-eabi-gcc.exe: error: CreateProcess: No such file or directory
The command 'arm-none-eabi-gcc.exe' failed with exit code '1'.
--------------- Rebuild Failed: 03/02/2016 10:11:55 ---------------
Environment:
PSoC Creator 3.3 SP1 (3.3.0.7343)
Culture: English (United States)
OS Version: Microsoft Windows NT 6.0.6000.0
CLR Version: 4.0.30319.1
Installed CyInstaller Products:
CY8CKIT-042-BLE Kit 1.0 Rev.*D
Cypress Document Manager 1.0 SP1
CySmart 1.2
PSoC Programmer 3.24.0
Loaded Plugins:
Version: 3.3.0.7343
Company: Cypress Semiconductor
Description: Loads component customizers.
Name: Addin Discovery
Version: 3.3.0.7343
Description: Discovers PSoC Creator addins (kits, language packs, etc)
Version: 3.3.0.7343
Description: Device Catalog Plugin
Version: 3.3.0.7343
Description: Adds the topics available in the documentation.
Version: 3.3.0.7343
Description: Adds a start page to the framework.
Version: 3.3.0.7343
Description: Add a feedback page to the framework
Name: Output Window Plugin
Version: 3.3.0.7343
Description: Adds the output window
Version: 3.3.0.7343
Description: The Source Code Control Manager is the central class used for SCC actions within PSoC Creator.
Name: Symbol, Schematic and SchMacro Factory
Version: 3.3.0.7343
Description: The Symbol and Schematic Factory is used to load, cache, and retrieve symbols and schematics.
Name: Project Manager Plugin
Version: 3.3.0.7343
Description: Adds project management related functionality.
Name: File Editor Factory Plugin
Version: 3.3.0.7343
Description: Add file editors to the framework.
Version: 3.3.0.7343
Description: Loads the Symbol and Schematic editors
Version: 3.3.0.7343
Description: Supports user files in multiple languages
Version: 3.3.0.7343
Description: The Workspace Factory is used to retrieve instances of PSoC Creator workspaces.
Version: 3.3.0.7343
Description: The Project Factory is used to retrieve instances of PSoC Creator projects.
Version: 3.3.0.7343
Description: PSoC Creator Toolchain Manager
Name: ARM GCC Generic
Version: 3.3.0.7343
Description: ARM GNU Generic
Name: ARM MDK Generic
Version: 3.3.0.7343
Description: ARM MDK Generic
Name: ARM IAR Generic
Version: 3.3.0.7343
Description: ARM IAR Generic
Name: DP8051 Keil Generic
Version: 3.3.0.7343
Description: DP8051 Keil Generic
Version: 3.3.0.7343
Description: Adds a dialog that allows the user to select a device.
Name: Transport Framework
Version: 3.3.0.7343
Description: Provides a generic device communication framework for use by other plugins.
Version: 3.3.0.7343
Description: The Core Debugger provides an architecture independent framework for the common debug features.
Version: 3.3.0.7343
Description: Provides debugging support for the different PSoC families through a GDB backend.
Name: Device IO Transport
Version: 3.3.0.7343
Description: Provides device IO support for Cypress devices though PSoC Programmer APIs.
Name: Serial Transport
Version: 3.3.0.7343
Description: Provides basic serial device support for the rest of the tool.
Version: 3.3.0.7343
Description: Provides a host tool to perform bootloading operations.
Name: Background Elaborator
Version: 3.3.0.7343
Description: PSoC Creator Background Elaborator.
Version: 3.3.0.7343
Description: The TypeCache Factory is used to retrieve instances of TypeCaches.
Version: 3.3.0.7343
Description: Registers resource editors with devices.
Version: 3.3.0.7343
Description: Enables quick and correct development of applications that use DMA.
Version: 3.3.0.7343
Description: Manages custom component tuner executables
Version: 3.3.0.7343
Description: The Notice Window displays notices (status messages / errors with managed lifetimes).
Thank you!
Bob
The solution is apparently not to run this software on a 32-bit Vista PC. See the following:
It seems to be a bug in GCC on a Vista machine and probably might not be fixed.
https://answers.launchpad.net/gcc-arm-embedded/+question/257200
The stackoverflow has some workarounds which even we think are the only workarounds but little complicated. This is machine specific as well as we are not able to reproduce on our side on 32 bit vista machine.
Bob
Don't you think it might be easier to tell us what worked and what didn't?
Bob
"arm-none-eabi-gcc.exe -mcpu=cortex-m0 -mthumb -Wno-main -I. -IGenerated_Source\PSoC4 -Wa,-alh=.\CortexM0\ARM_GCC_493\Debug/main.lst -g -D DEBUG -Wall -ffunction-sections -O0 -ffat-lto-objects -c .\main.c -o .\CortexM0\ARM_GCC_493\Debug\main.o
arm-none-eabi-gcc.exe: error: CreateProcess: No such file or directory"
Bob
This from a newly installed PSoC Creator and an unchanged example project.
Bob
