Hello everyone;
                       I am writing smartcard using i2c communication in PSoC 3. when  debugging code i got the following error . such as syntax error near uint8. Actually uint8 is a valid data types in psoc  compiler.other error is ``buffer"  undefined identifier .but buffer is already defined.  why it show like this.  I searched internet about this error but i can't get answer.. Please help me .
main.c
#include "project.h"
#include "I2C.h"
uint8 a,zone;
for( zone=0;zone<5;zone++)
  uint8 set(uint8 address, uint8 *Data,uint8 Num);
CyGlobalIntEnable;
uint8 set(uint8 address, uint8 *Data, uint8 Num)
Num=3;
address=0xB0;
if(zone==0)
      uint8 buffer[]={03,00,00};
      Data=buffer;
   else if(zone==1)
    for(a=0;a<3;a++)
        Data=0;
    uint8 buffer[]={03,01,00};//syntax error near 'uint8'
    Data=buffer;
  else if(zone==2)
     for(a=0;a<3;a++)
        Data=0;
    uint8 buffer[]={03,02,00};//syntax error near 'uint8'
    Data=buffer;//undefined identifier
    else if (zone==3)
        for(a=0;a<3;a++)
       Data=0;
    uint8 buffer[]={03,03,00};//syntax error near 'uint8'
    else
        return 0;
uint8 I2C_Send(uint8 address,uint8 *Data,uint8 Num);//syntax error near 'uint8'
uint8 writezone(uint8 address,uint8 *Data,uint8 Num);
uint8 writezone(uint8 address ,uint8 *Data,uint8 Num)
address=0xB4;
        if(zone==0)
            Num=8;
    for(a=0;a<3;a++)
        Data=0;
     uint8 buffer[]={00,00,05,00,07,03,04,03};
    Data=buffer;
  else if(zone==1)
     Num=0;
    Num=7;
    for(a=0;a<8;a++)
        Data=0;
    uint8 buffer[]={00,00,04,00,07,03,05};
    Data=buffer;
    else if(zone==2)
     Num=0;
     Num=6;
        for(a=0;a<7;a++)
        Data=0;
      uint8 buffer[]={00,00,03,00,65,73};
       Data=buffer;
    else if(zone==3)
        Num=0;
        Num=5;
         for(a=0;a<6;a++)
        Data=0;
     uint8 buffer[]={00,00,02,74,76};
    Data=buffer;
        else
        return 0;
    uint8 Readzone(uint8 address,uint8 *Data,uint8 Num);
uint8 Readzone(uint8 address,uint8 *Data , uint8 Num)
address=0xB2;
    Num=3;
    if(zone==0)
     for(a=0;a<8;a++)
        Data=0;
    uint8 buffer[]={00,00,05};
    Data=buffer;
    else if(zone==1)
     for(a=0;a<7;a++)
        Data=0;
     uint8 buffer[]={00,00,04};
    Data=buffer;
     else if(zone==2)
     for(a=0;a<6;a++)
        Data=0;
     uint8 buffer[]={00,00,03};
    Data=buffer;
       else if(zone==3)
     for(a=0;a<5;a++)
        Data=0;
     uint8 buffer[]={00,00,02};
    Data=buffer;
        else
        return 0;
    uint8 I2C_Read(uint8 address,uint8 *Data, uint8 Num);
Roy_Liu
5 comments on KBA First comment on KBA 10 questions asked
Should variables be defined and initialized at the beginning of a function?
Roy Liu
It is always easier for us looking for issues when you post your complete project so that we all can have a look at all of your settings. To do so, use
Bob
