- Email to a Friend
Just Setting up CY8CKIT042BLEKIT, and I am getting the following PSoC Programmer error (Cut & past):
| KitProg Version 2.10 Firmware Update Finished at 2:34:59 PM
| FAILED! Failed at BlockID = 40 SubPkt = 0 Msg = The data is not of the proper form.. Please replug KitProg.
| Upgrading...
| Initializing... Firmware Upgrade Started at 2:34:48 PM
| Firmware Upgrade Requested at 2:34:48 PM
| Please navigate to the Utilities tab and click the Upgrade Firmware button Port Opened with Warnings at 2:33:28 PM
| KitProg version Expecting 2.14, but found 2.10. Opening Port at 2:33:27 PM
| Device set to CY7C65215-32LTXI at 2:33:27 PM
32768 FLASH bytes Device Family set to CY7C65210 at 2:33:27 PM
| Active HEX file set at 2:33:26 PM
| Users must be aware that the following PSoC device should not be powered or programmed at 5V. Doing so will cause damage to the device: CYRF89xxx
Session Started at 2:33:26 PM
| PPCOM Version 20.0
Everything has been updated. CySmart and initial H/W demo works.
Thanks!
Bob
- Email to a Friend
Solved. Apparently you have to select the KitProg before you “Please navigate to the Utilities tab and click the Upgrade Firmware button”.
Bob
- Email to a Friend
Bob
