PSoC™ Creator & Designer
My project works fine in debug mode, except when i do a mdoify on the "main" function.
Older "main" function:
    BoardDriverInit();
    /* Place your initialization/startup code here (e.g. MyInst_Start()) */
    //asr_at_commands(0);
    application_start();
    for(;;)
        /* Place your application code here. */
when in debug mode, it appears:
Newer "main" function:
    BoardDriverInit();
    asr_at_commands(0);
    //application_start();
    for(;;)
in summary, the total project is same except that there is a little change in "main" function, then in debug mode the behaviour is different and debug not start in main" function.
RyanZhao
Hi Qipan,
Could you let us know more details about asr_at_commands(0);and //application_start();?
How about their declaration?
Also you can do a comparison of these two functions by yourself.
Ryan
AlanH_86
That is curious.
Try a clean and build
