PSoC™ Creator & Designer
Today April-30 2018 I removed all Cypress software from my system because Psoc creator 4.2 could not detect a debug target on CY8CKIT-049-42xx
After cleaning up I reinstalled PSOC creator 4.2 I still do get the same result.
I have PSoC creator 4.2 (4.2.0.641)
OS Microsoft Windows NT 6.1.7601 SP1
Installer CyInstaller product
CY8CKIT-049-42xx
First time i encounter problems with PSOC creator ;-(
Need solution quickly...
(added tiny test project)
Michiel de Jong
Oops,
Feel pretty stupid.
Been a while ago and I just plugged in the Kit 49 into the USB as I used in my applications.
Always used it with miniprog3 to program it.
Sorry.
Met vriendelijk groeten/Best Regards
Michiel de Jong
FPP solutions Group
Philips Research
High Tech Campus 34, room 3.067, 5656 AE Eindhoven, NL
Mobile +31 6 12373119
E-mail:Michiel.de.Jong@Philips.com
Bob_Marlowe
Expert II
The CY8CKIT-049-42xx has got no debug capabilities. You would need a Kitprog or a Miniprog3 to debug the chip on your kit. Cheapest solution for you would be to buy a Prototype Kit ie. CY8CKIT-043.
Bob
Hello Bob,
When I set the IDE to Release it still does not find a target.
Up till Creator 4.1 I have been using this kit for many projects……
Michiel de Jong
FPP solutions Group
Philips Research
rola_264706
Honored Contributor II
pastedImage_0.pngYou need this component in your program for the boot loader to work.  I have heard that they where going to remove this kit because of the issues with debug and programming.  I would use a new kit it will be easier.
Oops,
Feel pretty stupid.
Sorry.
Michiel de Jong
FPP solutions Group
Philips Research
