PSoC™ Creator & Designer
Since upgrading my PC to Win 10 PSoC Programmer simply hangs when using the miniprog3.  This happens if the miniprog3 is changed (connected)  to a different USB port.  I then need to stop the process via the Windows Task Manager.  After a couple of iterations of this and then letting the Programmer sit for a long while it will then correct itself and start responding.
I have checked the forums and can't find an issue that relates to this.
Ron
