PSoC™ Creator & Designer
Hi, I used the multiple topology wizard for placing DelSig or LPFilters in any allowed position until some days ago. Something changed in the basic setup of the computer/PSoC Desiner and since then the Wizard does not open and it only shows an XML file instead the execution of the file. I have remove all .NET versions and reinstall. I have remove Designer 5.0 and install Designer 5.1 but the failure remains.
I have tried to open a case with the problem, but this time Cypress seems not wanted to answer. It is curious because they always have help us very responsively.
Any idea?
Any idea?
this is a serious issue and we would like to get more specifics to make sure we find the root cause.
Could you please send my an e-mail to rtcy -at- cypress -dot- com so that we can communicate directly. Once we found a solution I am more than happy to post it here on the forum.
Robert
