PSoC™ Creator & Designer
radhika
New Contributor II
I am working on Legacy Code of the organization.
Code was compiled using : PSoC Creator 1.0 Service Pack 2. For some important tasks in the organisation I need to re-compile the code using the same IDE version. Though I searched your website, didn't get this IDE version even in Archive.
Please do help me here at your earliest
ncbs
Hello @radhika,
I apologize for the delay caused in sharing the ISO file.
Please find the link: PSoC Creator v1.0 SP2
Nikhil
Application Engineer @Cypress Semiconductors (An Infineon Technologies company)
ncbs
Hello @radhika ,
PSoC Creator 1.0 version has been removed from the archive page.
We would update here regarding the accessibility of PSoC Creator 1.0 version at the earliest.
Nikhil
ncbs
Hello @radhika ,
We do not offer PSoC Creator versions below v2.1.
You may proceed ahead to work on the oldest version of PSoC Creator available and check if it works for you, as most versions are forward compatible.
Nikhil
radhika
New Contributor II
Hello Nikhil,
The old compile version has device revision as Production type. But if I try to compile the same code keeping the device revision as Production, I am getting error.
My device is CY8C3866AXI-040. Please guide me to resolve or workaround for this issue.
Regards.
ncbs
Hello @radhika ,
Can you try updating the project by heading to Project -> Update components?
Nikhil
radhika
New Contributor II
Hello @nikhil, @ncbs ,
I have tried updating components.
I am keen to know workaround for device revision , if I choose device revision as Production/ES3...the code doesnt compile and throws assembler error as Forward reference not allowed.  But if I select device revision as ES2, it compiles. But I want work around/resolution for device revision as Production, which will after compilation match the binary image.
Radhika
radhika
New Contributor II
Hello @ncbs ,
Regards.
radhika
New Contributor II
Hello @ncbs
I need  PSoC Creator v1.0 SP2 to compile the code for the acquired product. Thus, one of the important task for the  acquired product  management is to compile the code and match the existing binary with the compiled one.
I have tried with the various PSoC IDE versions, but was not able to get the binary matching the previous one.
Is there any process in Cypress to get the  old versions of PSoC creator .
ncbs
Hello @radhika,
I will be sharing the PSoC Creator v1.0 SP2 with you. We are hosting the software on a secure platform before it can be shared.
Nikhil
radhika
New Contributor II
Hello  @ncbs , Nikhil,
Thanks a lot for the support. Will be waiting for the Software. I work with Natus Medical Incorporated as the Firmware Engineer.
ncbs
Hello @radhika,
Nikhil
radhika
New Contributor II
Thank you @ncbs , Nikhil.
Radhika
