PSoC™ Creator & Designer
Psoc Creater and Programmer were installed on my D:/ disk. Also, I can run PSoC Creator and use after the reinstallation of Windows on C:/ disk. Then, I need to install CY8CKIT059 package but when I run installer, there is a message: "You must download and install prerequisite(s): Psoc Creater and Programmer". What can I do for this problem? Must I reinstall PSoC apps?
AnkitaS_51
Please first uninstall PSoC Creator from D:/ disk and C:/ both.Then download the PSoC Creator4.2 from this link:
http://www.cypress.com/products/psoc-creator-integrated-design-environment-ide
Then, install the PSoC Creator with Admin Rights on C:/ and then try to install the CY8CKIT-059 Kit Only (Kit Design Files, Documentation, Examples) from this link:
http://www.cypress.com/documentation/development-kitsboards/cy8ckit-059-psoc-5lp-prototyping-kit-onb...
AnkitaS_51
Thanks, it was solved.
