PSoC™ Creator & Designer
CaKu_4284131
Contributor II
I am having a problem with PSoC Creator crashing, repeatedly, even when it is just idling in the background.
Environment:
PSoC Creator  4.2 (4.2.0.641)
Culture: English (United States)
OS Version: Microsoft Windows NT 10.0.18363.0
CLR Version: 4.0.30319.42000
Installed CyInstaller Products:
CySmart 1.3
Peripheral Driver Library 3.0.1
Peripheral Driver Library 3.0.3
Peripheral Driver Library 3.0.4
Peripheral Driver Library 3.1.1
PSoC Programmer 3.28.6
PSoC Creator 4.2
Loaded Plugins:
Version: 4.2.0.641
Company: Cypress Semiconductor
Description: Loads component customizers.
Name: Addin Discovery
Version: 4.2.0.641
Description: Discovers PSoC Creator addins (kits, language packs, etc)
Version: 4.2.0.641
Description: Device Catalog Plugin
Version: 4.2.0.641
Description: Adds the topics available in the documentation.
Version: 4.2.0.641
Description: Adds a start page to the framework.
Name: Output Window Plugin
Version: 4.2.0.641
Description: Adds the output window
Version: 4.2.0.641
Description: The Source Code Control Manager is the central class used for SCC actions within PSoC Creator.
Name: Symbol, Schematic and SchMacro Factory
Version: 4.2.0.641
Description: The Symbol and Schematic Factory is used to load, cache, and retrieve symbols and schematics.
Name: Project Manager Plugin
Version: 4.2.0.641
Description: Adds project management related functionality.
Version: 4.2.0.641
Description: Loads the Symbol and Schematic editors
Version: 4.2.0.641
Description: Supports user files in multiple languages
Version: 4.2.0.641
Description: The Workspace Factory is used to retrieve instances of PSoC Creator workspaces.
Version: 4.2.0.641
Description: The Project Factory is used to retrieve instances of PSoC Creator projects.
Version: 4.2.0.641
Description: PSoC Creator Toolchain Manager
Name: ARM GCC Generic
Version: 4.2.0.641
Description: ARM GNU Generic
Name: ARM MDK Generic
Version: 4.2.0.641
Description: ARM MDK Generic
Name: ARM IAR Generic
Version: 4.2.0.641
Description: ARM IAR Generic
Name: DP8051 Keil Generic
Version: 4.2.0.641
Description: DP8051 Keil Generic
Version: 4.2.0.641
Description: Adds a dialog that allows the user to select a device.
Name: File Editor Factory Plugin
Version: 4.2.0.641
Description: Add file editors to the framework.
Name: Transport Framework
Version: 4.2.0.641
Description: Provides a generic device communication framework for use by other plugins.
Version: 4.2.0.641
Description: The Core Debugger provides an architecture independent framework for the common debug features.
Version: 4.2.0.641
Description: Provides debugging support for the different PSoC families through a GDB back end.
Version: 4.2.0.641
Description: Provides debugging support for FM device families
Name: Device IO Transport
Version: 4.2.0.641
Description: Provides device IO support for Cypress devices though PSoC Programmer APIs.
Name: Serial Transport
Version: 4.2.0.641
Description: Provides basic serial device support for the rest of the tool.
Version: 4.2.0.641
Description: Provides a host tool to perform bootloading operations.
Name: Background Elaborator
Version: 4.2.0.641
Description: PSoC Creator Background Elaborator.
Version: 4.2.0.641
Description: The TypeCache Factory is used to retrieve instances of TypeCaches.
Version: 4.2.0.641
Description: PSoC Fitter Plugin
Version: 4.2.0.641
Description: FM Fitter Plugin
Version: 4.2.0.641
Description: Registers resource editors with devices.
Version: 4.2.0.641
Description: Enables quick and correct development of applications that use DMA.
Version: 4.2.0.641
Description: Manages custom component tuner executables
Version: 4.2.0.641
Description: The Notice Window displays notices (status messages / errors with managed lifetimes).
Microsoft (R) Windows Debugger Version 10.0.18362.1 X86
Copyright (c) Microsoft Corporation. All rights reserved.
*** wait with pending attach
Symbol search path is: srv*
Executable search path is:
ModLoad: 00ec0000 00fea000   C:\Program Files (x86)\Cypress\PSoC Creator\4.2\PSoC Creator\bin\psoc_creator.exe
ModLoad: 776a0000 7783a000   C:\WINDOWS\SYSTEM32\ntdll.dll
ModLoad: 74bc0000 74c12000   C:\WINDOWS\SYSTEM32\MSCOREE.DLL
ModLoad: 773c0000 774a0000   C:\WINDOWS\System32\KERNEL32.dll
ModLoad: 74f20000 7511c000   C:\WINDOWS\System32\KERNELBASE.dll
ModLoad: 75800000 75879000   C:\WINDOWS\System32\ADVAPI32.dll
ModLoad: 76490000 7654f000   C:\WINDOWS\System32\msvcrt.dll
ModLoad: 77610000 77686000   C:\WINDOWS\System32\sechost.dll
ModLoad: 76b50000 76c0b000   C:\WINDOWS\System32\RPCRT4.dll
ModLoad: 74e70000 74e90000   C:\WINDOWS\System32\SspiCli.dll
ModLoad: 74e60000 74e6a000   C:\WINDOWS\System32\CRYPTBASE.dll
ModLoad: 76a40000 76a9f000   C:\WINDOWS\System32\bcryptPrimitives.dll
ModLoad: 74b30000 74bbd000   C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll
ModLoad: 76aa0000 76ae4000   C:\WINDOWS\System32\SHLWAPI.dll
ModLoad: 767c0000 76a36000   C:\WINDOWS\System32\combase.dll
ModLoad: 774c0000 775df000   C:\WINDOWS\System32\ucrtbase.dll
ModLoad: 775e0000 77601000   C:\WINDOWS\System32\GDI32.dll
ModLoad: 76280000 76297000   C:\WINDOWS\System32\win32u.dll
ModLoad: 76c70000 76dca000   C:\WINDOWS\System32\gdi32full.dll
ModLoad: 76300000 7637c000   C:\WINDOWS\System32\msvcp_win.dll
ModLoad: 75920000 75ab7000   C:\WINDOWS\System32\USER32.dll
ModLoad: 76380000 763a5000   C:\WINDOWS\System32\IMM32.DLL
ModLoad: 774b0000 774bf000   C:\WINDOWS\System32\kernel.appcore.dll
ModLoad: 74ad0000 74ad8000   C:\WINDOWS\SYSTEM32\VERSION.dll
ModLoad: 6dae0000 6e290000   C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll
ModLoad: 74b10000 74b24000   C:\WINDOWS\SYSTEM32\VCRUNTIME140_CLR0400.dll
ModLoad: 74090000 7413b000   C:\WINDOWS\SYSTEM32\ucrtbase_clr0400.dll
ModLoad: 6c6d0000 6dade000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\mscorlib\48544608ee1424c9c713d99c7a353349\mscorlib.ni.dll
ModLoad: 75700000 757f7000   C:\WINDOWS\System32\ole32.dll
ModLoad: 72b10000 72b8a000   C:\WINDOWS\system32\uxtheme.dll
ModLoad: 6bc70000 6c6c5000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System\47d8098623206eb9197e176cf4d0dca1\System.ni.dll
ModLoad: 6a5e0000 6adf8000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Core\95d63de0b8688a92411233359dfa02e2\System.Core.ni.dll
ModLoad: 69bf0000 69d4c000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\psoc_creator\b1112aea617d68dec2a839acb686ddf6\psoc_creator.ni.exe
ModLoad: 69980000 69bec000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cydevicedb\2b87718d8efb8ac4e1d5d2330295a1e3\cydevicedb.ni.dll
ModLoad: 69180000 69979000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cycmbase\93eed4fcb92aca00cd8293a8b4f20057\cycmbase.ni.dll
ModLoad: 73e50000 73ff3000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Drawing\b92cd4ed839a488ace393f4cb14513dd\System.Drawing.ni.dll
ModLoad: 6ae00000 6bc66000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Windows.Forms\cb9c9e9b019c07ef7745bfe5cf994892\System.Windows.Forms.ni.dll
ModLoad: 68e10000 69179000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\CyFramework\7405c2ef765b19488df247e626d1230b\CyFramework.ni.dll
ModLoad: 689a0000 68e0b000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cygde\8fc2679a304fc29e9559b4b12060d509\cygde.ni.dll
ModLoad: 77380000 77393000   C:\WINDOWS\System32\CRYPTSP.dll
ModLoad: 742b0000 742df000   C:\WINDOWS\system32\rsaenh.dll
ModLoad: 773a0000 773b9000   C:\WINDOWS\System32\bcrypt.dll
ModLoad: 680c0000 68995000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\CyPrjMgmt\d09f0f8b9b02be515b85431eae9b3ae9\CyPrjMgmt.ni.dll
ModLoad: 67b70000 680ba000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cys3db\c2b1704f4be7b1090933b254e41e6394\cys3db.ni.dll
ModLoad: 6eaa0000 6eb77000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cygdegfxlib\9ca0c9999533b5af50db2c4e2ea72c88\cygdegfxlib.ni.dll
ModLoad: 67940000 67b69000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cydebugger\c74e2e10f3db811906aab1505a7ae64b\cydebugger.ni.dll
ModLoad: 6a4d0000 6a5d5000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Configuration\d6ee3b23e4bd762ef2b619462a421a44\System.Configuration.ni.dll
ModLoad: 69d50000 6a4c4000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Xml\9c3f67b6ff805d47e68c80083d041fcb\System.Xml.ni.dll
ModLoad: 75ac0000 7603a000   C:\WINDOWS\System32\shell32.dll
ModLoad: 762a0000 762db000   C:\WINDOWS\System32\cfgmgr32.dll
ModLoad: 76400000 76484000   C:\WINDOWS\System32\shcore.dll
ModLoad: 75120000 756e5000   C:\WINDOWS\System32\windows.storage.dll
ModLoad: 76f10000 76f27000   C:\WINDOWS\System32\profapi.dll
ModLoad: 763b0000 763f3000   C:\WINDOWS\System32\powrprof.dll
ModLoad: 762f0000 762fd000   C:\WINDOWS\System32\UMPDC.dll
ModLoad: 6edb0000 6ee3d000   C:\WINDOWS\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.18362.592_none_71d995095ae1acb5\comctl32.dll
ModLoad: 74000000 74089000   C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll
ModLoad: 75880000 75912000   C:\WINDOWS\System32\OLEAUT32.dll
ModLoad: 67680000 67937000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\UIFramework27e30c2d#\e146da33dc1038964598a7cadd29f45d\UIFramework.Product6.WinForms.ni.dll
ModLoad: 67590000 67675000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\UIFramework6baa8ba9#\2b51a70bc758181ce7e110097b49b11b\UIFramework.Product2.WinForms.ni.dll
ModLoad: 67210000 6728a000   C:\WINDOWS\SYSTEM32\RichEd20.DLL
ModLoad: 73dd0000 73de7000   C:\WINDOWS\SYSTEM32\USP10.dll
ModLoad: 6e690000 6e6c1000   C:\WINDOWS\SYSTEM32\msls31.dll
ModLoad: 729a0000 72b09000   C:\WINDOWS\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.18362.592_none_5f58db4d822160d6\gdiplus.dll
ModLoad: 67290000 67510000   C:\WINDOWS\SYSTEM32\DWrite.dll
ModLoad: 760a0000 761a3000   C:\WINDOWS\System32\MSCTF.dll
ModLoad: 67070000 67206000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\UIFrameworkd5b6bc6f#\8bd428caab8cfb8758fe68061ac14c58\UIFramework.Product4.WinForms.ni.dll
ModLoad: 66210000 66369000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\UIFrameworkb187348e#\127018908f87c84073d54a1a002e7a8d\UIFramework.Product5.WinForms.ni.dll
ModLoad: 6e660000 6e690000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\CyShared\f9c102a435b54b31aae01d3147e35d72\CyShared.ni.dll
ModLoad: 67010000 67065000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cyautomation\02042629503ddcb0e898638c28433315\cyautomation.ni.dll
ModLoad: 66e00000 66f30000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Management\76fe38b0865b2fe4284bb13fc1dd04e7\System.Management.ni.dll
ModLoad: 74ea0000 74f20000   C:\WINDOWS\System32\clbcatq.dll
ModLoad: 6f230000 6f24d000   C:\WINDOWS\system32\wbem\wmiutils.dll
ModLoad: 66d90000 66df9000   C:\WINDOWS\SYSTEM32\wbemcomn.dll
ModLoad: 76040000 7609e000   C:\WINDOWS\System32\WS2_32.dll
ModLoad: 74d70000 74d7d000   C:\WINDOWS\system32\wbem\wbemprox.dll
ModLoad: 66d60000 66d81000   C:\Windows\Microsoft.NET\Framework\v4.0.30319\wminet_utils.dll
ModLoad: 6ea90000 6eaa0000   C:\WINDOWS\system32\wbem\wbemsvc.dll
ModLoad: 66c90000 66d5b000   C:\WINDOWS\system32\wbem\fastprox.dll
ModLoad: 6ea80000 6ea8f000   C:\WINDOWS\SYSTEM32\amsi.dll
ModLoad: 74d50000 74d6e000   C:\WINDOWS\SYSTEM32\USERENV.dll
ModLoad: 66c50000 66c88000   C:\ProgramData\Microsoft\Windows Defender\platform\4.18.2001.7-0\X86\MpOav.dll
ModLoad: 72ba0000 72d4b000   C:\WINDOWS\SYSTEM32\urlmon.dll
ModLoad: 72130000 72359000   C:\WINDOWS\SYSTEM32\iertutil.dll
ModLoad: 72060000 72125000   C:\WINDOWS\SYSTEM32\PROPSYS.dll
ModLoad: 6ef60000 6f0c9000   C:\WINDOWS\SYSTEM32\WindowsCodecs.dll
ModLoad: 737c0000 739cf000   C:\WINDOWS\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.18362.592_none_2e6de868278ee708\comctl32.dll
ModLoad: 66c10000 66c41000   C:\WINDOWS\system32\dataexchange.dll
ModLoad: 66a30000 66c0e000   C:\WINDOWS\system32\d3d11.dll
ModLoad: 668c0000 66a29000   C:\WINDOWS\system32\dcomp.dll
ModLoad: 667f0000 668b1000   C:\WINDOWS\system32\dxgi.dll
ModLoad: 6e760000 6e779000   C:\WINDOWS\SYSTEM32\dxcore.dll
ModLoad: 6f710000 6f8f4000   C:\WINDOWS\system32\twinapi.appcore.dll
ModLoad: 6f6f0000 6f70f000   C:\WINDOWS\system32\RMCLIENT.dll
ModLoad: 66600000 667e6000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Web.Services\5297d6ca2950ddf942c4b4f084c569d2\System.Web.Services.ni.dll
ModLoad: 67510000 67532000   C:\WINDOWS\SYSTEM32\wldp.dll
ModLoad: 76550000 7664b000   C:\WINDOWS\System32\CRYPT32.dll
ModLoad: 74e90000 74e9e000   C:\WINDOWS\System32\MSASN1.dll
ModLoad: 761b0000 761f6000   C:\WINDOWS\System32\WINTRUST.dll
ModLoad: 66f60000 6700c000   C:\ProgramData\Microsoft\Windows Defender\platform\4.18.2001.7-0\X86\MPCLIENT.DLL
ModLoad: 74c80000 74c9e000   C:\WINDOWS\SYSTEM32\gpapi.dll
ModLoad: 61b10000 61b94000   C:\WINDOWS\System32\TextInputFramework.dll
ModLoad: 618b0000 61b0e000   C:\WINDOWS\System32\CoreUIComponents.dll
ModLoad: 61820000 618a9000   C:\WINDOWS\System32\CoreMessaging.dll
ModLoad: 6ece0000 6ed09000   C:\WINDOWS\SYSTEM32\ntmarta.dll
ModLoad: 6fc60000 6fd3a000   C:\WINDOWS\SYSTEM32\wintypes.dll
ModLoad: 664c0000 66513000   C:\WINDOWS\system32\Oleacc.dll
ModLoad: 6e790000 6e79d000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\Accessibility\241c057f2f528b30cc339b80b89b93c6\Accessibility.ni.dll
ModLoad: 66580000 665f1000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cydsextensions\23aa99e1cd65356945c75ff665c26d18\cydsextensions.ni.dll
ModLoad: 6ec10000 6ec98000   C:\WINDOWS\SYSTEM32\sxs.dll
ModLoad: 663f0000 6643a000   C:\Windows\System32\thumbcache.dll
ModLoad: 66370000 663e3000   C:\WINDOWS\SYSTEM32\policymanager.dll
ModLoad: 6ee40000 6eea5000   C:\WINDOWS\SYSTEM32\msvcp110_win.dll
ModLoad: 660b0000 6620f000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cyeditors\1b12df4699b431f505cc27be6088963d\cyeditors.ni.dll
ModLoad: 65ef0000 660a9000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\UIFramework6c15ec7e#\6b716ed8e64d04cadb0d105f27a3d81b\UIFramework.Product6.Addons.DotNet.WinForms.ni.dll
ModLoad: 65e20000 65ee6000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cytransport\5a7384f9d43931d885606c8fb29739da\cytransport.ni.dll
ModLoad: 66520000 66575000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cypsocdebugger\04f2285957ad2225baef6cb7a0fb13a2\cypsocdebugger.ni.exe
ModLoad: 65d50000 65e12000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cygdbdebugger\044434dfa07c36935e7f5dfd47de6787\cygdbdebugger.ni.dll
ModLoad: 67550000 6758a000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cyarmdebugger\e1801c883d242f2dcd76592d59874a10\cyarmdebugger.ni.dll
ModLoad: 66440000 664bb000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cyppdeviceio\51365e5533b2afc8fd6bf680e1134fd1\cyppdeviceio.ni.dll
ModLoad: 65ce0000 65d4e000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cywin32deviceio\82760afbfca53529b38f406c871846a7\cywin32deviceio.ni.dll
ModLoad: 65c60000 65cdd000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\bootloader_host\4d4f2403d7e65e9c694d225a7e81ae83\bootloader_host.ni.exe
ModLoad: 649f0000 65c54000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cydsfit\90308634b0d61866d284321d06c06a28\cydsfit.ni.exe
ModLoad: 64860000 649e9000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cyfitter_fm\a480bd846de94708850a0892ab1f1049\cyfitter_fm.ni.exe
ModLoad: 641c0000 6485b000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cyfitlib\f860370ebaebab68ec81471939d3fa2b\cyfitlib.ni.dll
ModLoad: 64130000 6417d000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Draw0a54d252#\04fad7d5f1e47ee2357f65963636898f\System.Drawing.Design.ni.dll
ModLoad: 635e0000 6365d000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\ICSharpCoded64bfd68#\fc3294738e7f1904d9ab4d1254fe169a\ICSharpCode.SharpZipLib.ni.dll
ModLoad: 63660000 6412a000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Design\aa2fd3af98876091638509af8f7fc616\System.Design.ni.dll
ModLoad: 64180000 641be000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\UIFrameworkf54eb40a#\1b81687041a55159e8babdf0c3352077\UIFramework.Product1.WinForms.ni.dll
ModLoad: 6e580000 6e59d000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cyhextool\1e9a95d8e3c4d71e80e96e900c72a77f\cyhextool.ni.exe
ModLoad: 67540000 67547000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cykeilspawner\c14a6ee30e5508f239fa4f7c2d9bce22\cykeilspawner.ni.exe
ModLoad: 66f50000 66f56000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cytunerextensions\009f4fa84f9a4c193f324c9ba795ae25\cytunerextensions.ni.dll
ModLoad: 635b0000 635d5000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cyclangwrapper\104f216d9d3d12a16f8aed819eca066b\cyclangwrapper.ni.dll
ModLoad: 66f30000 66f47000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\PP_Accessor\88b8a2cc697192c1d8948c21d75dafcb\PP_Accessor.ni.dll
ModLoad: 635a0000 635a6000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cyp3fit\1ae61a0adbb1d29e975d4b51be100e91\cyp3fit.ni.exe
ModLoad: 634b0000 634d1000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\AxInterop.SHDocVw\b0bb36d6d093390e0d6805671250d308\AxInterop.SHDocVw.ni.dll
ModLoad: 63440000 634a9000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\Interop.SHDocVw\4c543d23c87f49b8e901be53d4742677\Interop.SHDocVw.ni.dll
ModLoad: 62e40000 6343a000   C:\Windows\System32\ieframe.dll
ModLoad: 72610000 726cd000   C:\Windows\System32\WINHTTP.dll
ModLoad: 74370000 74383000   C:\Windows\System32\NETAPI32.dll
ModLoad: 6f6d0000 6f6e0000   C:\Windows\System32\WKSCLI.DLL
ModLoad: 70600000 7060b000   C:\Windows\System32\NETUTILS.DLL
ModLoad: 62df0000 62e33000   C:\WINDOWS\SYSTEM32\msIso.dll
ModLoad: 74660000 74abc000   C:\WINDOWS\SYSTEM32\WININET.dll
ModLoad: 6ffb0000 6ffc2000   C:\WINDOWS\SYSTEM32\ondemandconnroutehelper.dll
ModLoad: 705a0000 705f2000   C:\WINDOWS\system32\mswsock.dll
ModLoad: 74500000 74532000   C:\WINDOWS\SYSTEM32\IPHLPAPI.DLL
ModLoad: 762e0000 762e7000   C:\WINDOWS\System32\NSI.dll
ModLoad: 6ffa0000 6ffa8000   C:\WINDOWS\SYSTEM32\WINNSI.DLL
ModLoad: 61ba0000 62de3000   C:\WINDOWS\SYSTEM32\MSHTML.dll
ModLoad: 707b0000 70841000   C:\WINDOWS\SYSTEM32\DNSAPI.dll
ModLoad: 6fda0000 6fda8000   C:\Windows\System32\rasadhlp.dll
ModLoad: 6fd40000 6fd91000   C:\WINDOWS\System32\fwpuclnt.dll
ModLoad: 6fbe0000 6fc56000   C:\WINDOWS\System32\schannel.dll
ModLoad: 756f0000 756f6000   C:\WINDOWS\System32\psapi.dll
ModLoad: 6f9f0000 6fa00000   C:\WINDOWS\SYSTEM32\mskeyprotect.dll
ModLoad: 72030000 72051000   C:\WINDOWS\SYSTEM32\ncrypt.dll
ModLoad: 70a10000 70a38000   C:\WINDOWS\SYSTEM32\NTASN1.dll
ModLoad: 6fdb0000 6fdb8000   C:\WINDOWS\SYSTEM32\DPAPI.DLL
ModLoad: 6f9c0000 6f9e6000   C:\Windows\System32\cryptnet.dll
ModLoad: 74d80000 74e5b000   C:\WINDOWS\SYSTEM32\rasapi32.dll
ModLoad: 74ae0000 74b0b000   C:\WINDOWS\SYSTEM32\rasman.dll
ModLoad: 73df0000 73e01000   C:\WINDOWS\SYSTEM32\rtutils.dll
ModLoad: 6f1f0000 6f203000   C:\WINDOWS\SYSTEM32\dhcpcsvc6.DLL
ModLoad: 74140000 74155000   C:\WINDOWS\SYSTEM32\dhcpcsvc.DLL
ModLoad: 6f9a0000 6f9bf000   C:\WINDOWS\system32\ncryptsslp.dll
ModLoad: 6f210000 6f22b000   C:\WINDOWS\SYSTEM32\edputil.dll
ModLoad: 61790000 6181b000   C:\Windows\System32\Windows.StateRepositoryPS.dll
ModLoad: 70030000 7004b000   C:\WINDOWS\SYSTEM32\CLDAPI.dll
ModLoad: 70020000 70028000   C:\WINDOWS\SYSTEM32\FLTLIB.DLL
ModLoad: 61710000 61781000   C:\Windows\System32\appresolver.dll
ModLoad: 616c0000 61705000   C:\Windows\System32\Bcp47Langs.dll
ModLoad: 616a0000 616c0000   C:\Windows\System32\SLC.dll
ModLoad: 61680000 6169c000   C:\Windows\System32\sppc.dll
ModLoad: 61640000 6167b000   C:\Windows\System32\OneCoreCommonProxyStub.dll
ModLoad: 70170000 704fd000   C:\Windows\System32\OneCoreUAPCommonProxyStub.dll
ModLoad: 61530000 61635000   C:\Windows\Microsoft.NET\Framework\v4.0.30319\diasymreader.dll
ModLoad: 61400000 61507000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\cydstoolkit\26d78406ac0978f628a1f265f0c3cced\cydstoolkit.ni.dll
ModLoad: 72b90000 72b9a000   C:\WINDOWS\SYSTEM32\Secur32.dll
ModLoad: 70500000 70534000   C:\WINDOWS\SYSTEM32\MLANG.dll
ModLoad: 613d0000 613f6000   C:\WINDOWS\SYSTEM32\srpapi.dll
ModLoad: 61310000 613cc000   C:\WINDOWS\SYSTEM32\ieapfltr.dll
ModLoad: 61520000 6152e000   C:\WINDOWS\system32\msimtf.dll
ModLoad: 60f60000 6130c000   C:\Windows\System32\jscript9.dll
ModLoad: 72360000 7238b000   C:\WINDOWS\SYSTEM32\XmlLite.dll
ModLoad: 60a70000 60f5c000   C:\WINDOWS\SYSTEM32\d2d1.dll
ModLoad: 604d0000 60a6c000   C:\WINDOWS\SYSTEM32\d3d10warp.dll
ModLoad: 604a0000 604c5000   C:\WINDOWS\SYSTEM32\T2EMBED.DLL
ModLoad: 61510000 6151f000   C:\WINDOWS\SYSTEM32\ImgUtil.dll
ModLoad: 60320000 6049d000   C:\WINDOWS\SYSTEM32\MFPlat.dll
ModLoad: 602f0000 6031a000   C:\WINDOWS\SYSTEM32\RTWorkQ.DLL
ModLoad: 602c0000 602e8000   C:\WINDOWS\SYSTEM32\CompPkgSup.DLL
ModLoad: 5fde0000 602b1000   C:\Windows\System32\Windows.Media.dll
ModLoad: 5fd30000 5fdda000   C:\Windows\System32\Windows.ApplicationModel.dll
ModLoad: 6fef0000 6ff95000   C:\Windows\System32\AppXDeploymentClient.dll
ModLoad: 6fe80000 6fee1000   C:\Windows\System32\FirewallAPI.dll
ModLoad: 6fdf0000 6fe7a000   C:\Windows\System32\StateRepository.Core.dll
ModLoad: 6fdc0000 6fde5000   C:\Windows\System32\fwbase.dll
ModLoad: 5f2d0000 5f64e000   C:\Windows\System32\MFMediaEngine.dll
ModLoad: 5f940000 5f9a2000   C:\WINDOWS\System32\MMDevApi.dll
ModLoad: 74c20000 74c43000   C:\WINDOWS\System32\DEVOBJ.dll
ModLoad: 5f820000 5f93e000   C:\WINDOWS\SYSTEM32\AUDIOSES.DLL
ModLoad: 5f720000 5f820000   C:\Windows\System32\Windows.UI.dll
ModLoad: 5f650000 5f712000   C:\Windows\System32\InputHost.dll
ModLoad: 5fb30000 5fb9d000   C:\Windows\System32\Windows.Media.MediaControl.dll
ModLoad: 5f280000 5f2cd000   C:\Windows\System32\Windows.Media.Devices.dll
ModLoad: 76c10000 76c6e000   C:\WINDOWS\System32\coml2.dll
ModLoad: 5f1c0000 5f27c000   C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MigraDoc.Dobc997da6#\452115f2d1be017efc60184cb40ee915\MigraDoc.DocumentObjectModel.ni.dll
ModLoad: 78ae0000 7bb4e000   C:\Program Files (x86)\Cypress\PSoC Creator\4.2\PSoC Creator\bin\libclang.dll
ModLoad: 5f150000 5f1bc000   C:\Program Files (x86)\Cypress\PSoC Creator\4.2\PSoC Creator\bin\MSVCP140.dll
ModLoad: 5fbe0000 5fbf4000   C:\Program Files (x86)\Cypress\PSoC Creator\4.2\PSoC Creator\bin\VCRUNTIME140.dll
ModLoad: 5fb20000 5fb30000   C:\Windows\Microsoft.NET\Framework\v2.0.50727\System.EnterpriseServices.Thunk.dll
ModLoad: 5c130000 5c323000   C:\Windows\System32\uiautomationcore.dll
ModLoad: 709e0000 70a04000   C:\WINDOWS\SYSTEM32\WINMM.dll
ModLoad: 708a0000 708c3000   C:\WINDOWS\SYSTEM32\WINMMBASE.dll
(74c4.5104): Security check failure or stack buffer overrun - code c0000409 (!!! second chance !!!)
eax=00000001 ebx=0137e764 ecx=00000007 edx=000001e2 esi=00000003 edi=767e6600
eip=7755e6eb esp=0137e6a0 ebp=0137e6b0 iopl=0         nv up ei pl nz na po nc
cs=0023  ss=002b  ds=002b  es=002b  fs=0053  gs=002b             efl=00200202
ucrtbase!abort+0x4b:
7755e6eb cd29            int     29h
At first, I was running a large workspace with multiple projects, but I have pared that down to a single, fairly small, project, with no improvement.
How can I prevent this crash?
Rakshith
Hello CaKu_4284131​,
Please refer to this KBA and let us know if it helps resolves your issue - PSoC Creator May Crash when Run Concurrently with Visual Studio on Windows 10 - KBA226098
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Rakshith
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
CaKu_4284131
Contributor II
Thanks, Rakshith. I am running Visual Studio concurrently with PSoC Creator, but knowing that that is likely the problem doesn't really "resolve" the issue. Not being able to run them together is a rather annoying limitation given that I am porting code from the FreeRTOS Windows Simulator, and that code lives in Visual Studio. Fortunately, I am almost done with that process, but by the time I'm done I will have developed a nervous tic compelling me to hit the save button every few seconds!
Also, the KB article mentions Visual Studio version: 2015/2017, but I am running 2019:
Microsoft Visual Studio Community 2019
Version 16.4.4
VisualStudio.16.Release/16.4.4+29728.190
Microsoft .NET Framework
Version 4.8.03752
Installed Version: Community
Visual C++ 2019   00435-60000-00000-AA984
Microsoft Visual C++ 2019
ASP.NET and Web Tools 2019   16.4.460.23317
ASP.NET Web Frameworks and Tools 2019   16.4.460.23317
For additional information, visit https://www.asp.net/
Azure App Service Tools v3.0.0   16.4.460.23317
Azure Functions and Web Jobs Tools   16.4.460.23317
C# Tools   3.4.1-beta4-19614-01+165046097562cfe65b09c2e9a9d8f7cd88526f2c
C# components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Common Azure Tools   1.10
Provides common services for use by Azure Mobile Services and Microsoft Azure Tools.
Cookiecutter   16.4.19310.1
Provides tools for finding, instantiating and customizing templates in cookiecutter format.
IntelliCode Extension   1.0
IntelliCode Visual Studio Extension Detailed Info
Microsoft Azure Tools   2.9
Microsoft Azure Tools for Microsoft Visual Studio 2019 - v2.9.21016.1
Microsoft Continuous Delivery Tools for Visual Studio   0.4
Simplifying the configuration of Azure DevOps pipelines from within the Visual Studio IDE.
Microsoft JVM Debugger   1.0
Provides support for connecting the Visual Studio debugger to JDWP compatible Java Virtual Machines
Microsoft Library Manager   2.0.87+gbb515bf382
Install client-side libraries easily to any web project
Microsoft MI-Based Debugger   1.0
Provides support for connecting Visual Studio to MI compatible debuggers
Microsoft Visual C++ Wizards   1.0
Microsoft Visual Studio Tools for Containers   1.1
Develop, run, validate your ASP.NET Core applications in the target environment. F5 your application directly into a container with debugging, or CTRL + F5 to edit & refresh your app without having to rebuild the container.
Microsoft Visual Studio VC Package   1.0
NuGet Package Manager   5.4.0
NuGet Package Manager in Visual Studio. For more information about NuGet, visit https://docs.nuget.org/
ProjectServicesPackage Extension   1.0
ProjectServicesPackage Visual Studio Extension Detailed Info
Python   16.4.19310.1
Provides IntelliSense, projects, templates, debugging, interactive windows, and other support for Python developers.
Python - Conda support   16.4.19310.1
Conda support for Python projects.
Python - Django support   16.4.19310.1
Provides templates and integration for the Django web framework.
Python - IronPython support   16.4.19310.1
Provides templates and integration for IronPython-based projects.
Python - Profiling support   16.4.19310.1
Profiling support for Python projects.
SQL Server Data Tools   16.0.61912.09160
Microsoft SQL Server Data Tools
Test Adapter for Boost.Test   1.0
Enables Visual Studio's testing tools with unit tests written for Boost.Test.  The use terms and Third Party Notices are available in the extension installation directory.
Test Adapter for Google Test   1.0
Enables Visual Studio's testing tools with unit tests written for Google Test.  The use terms and Third Party Notices are available in the extension installation directory.
TypeScript Tools   16.0.11031.2001
TypeScript Tools for Microsoft Visual Studio
Visual Basic Tools   3.4.1-beta4-19614-01+165046097562cfe65b09c2e9a9d8f7cd88526f2c
Visual Basic components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Visual C++ for Linux Development   1.0.9.29512
Visual F# Tools 10.4 for F# 4.6   16.4.0-beta.19556.5+e7597deb7042710a7142bdccabd6f92b0840d354
Microsoft Visual F# Tools 10.4 for F# 4.6
Visual Studio Code Debug Adapter Host Package   1.0
Interop layer for hosting Visual Studio Code debug adapters in Visual Studio
Visual Studio Container Tools Extensions (Preview)   1.0
View, manage, and diagnose containers within Visual Studio.
Visual Studio Tools for CMake   1.0
Visual Studio Tools for Containers   1.0
Rakshith
Hi CaKu_4284131​,
This is a known issue and it is applicable for Visual Studio 2019 also.
Unfortunately, there is no workaround at the moment to simultaneously use PSoC Creator and Visual Studio.
The KBA will be updated once there is any workaround for this issue.
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
