PSoC™ Creator & Designer
While im trying to debug my code, i get the message that the source code cannot be found and the debugger jumps into the assembly code.
how can i fix it?
Thank you.
Bob_Marlowe
Expert II
Probably some settings are not as expected.
Are you using an unmodified "Debug" build configuration?
Are sources in a standard place?
If you may, you can create a "Workspace Bundle" and upload the complete project here (DO NOT use chrome, doesn't work).
Bob
 Are you using components make yourself?
