Upon startup of psoc_creator 4.2 i get the following
An error occurred loading a critical part definition file: (System.NullReferenceException: Object reference not set to an instance of an object.
at System.Xml.XmlReader.CalcBufferSize(Stream input)
at System.Xml.XmlTextReaderImpl.InitStreamInput(Uri baseUri, String baseUriStr, Stream stream, Byte[] bytes, Int32 byteCount, Encoding encoding)
at System.Xml.XmlTextReaderImpl..ctor(String url, Stream input, XmlNameTable nt)
at System.Xml.XmlDocument.Load(Stream inStream)
at CyDesigner.Common.Db.DeviceDb.Catalog.CyDcMiscArch.Parse(String miscArchFile)).
was fine for few week of use.
Running Window 10 on Dell
Apologies in advance if this is something simple that is dealt before. My search didnt show up anything relevant
PSoC Creator Software
Do you see any file of the name <workspace_name>.cywrk.<your_name>? It is an XML file which is created whenever a new workspace is created. Please check if you have that file. I will attach a file for your reference. If yes, please delete that file and start your project again. Let me know your observations.
Dheeraj
I think this error is specific to a project which might be failing to load. Do you have any other projects? If yes, can you try opening any other project in PSoC Creator by clicking on the <project_name>.cyprj file and then checking if you have any error?
If you still face the error, I think your install is corrupted and you might need a fresh install.
Dheeraj
Dheeraj
