anne_4609456
10 replies posted 25 sign-ins 5 questions asked
Hi.
I'm using sample code in C++ located in Cypress-SDK: "Cypress\Programmer\Examples\Programming\PSoC1\ISSP\Cpp_Ex" to program a HEX file to CY7C63803 chip.
It works fine, but I need to turn the PowerOn on PSoC Miniprog after write the firmware into device for test purpose.
I could not find PowerOn command in C++ (Cpp_Ex) sample code.
Could you send me a sample code in C++ to PowerOn and PowerOff the MiniProg using C++?
Thanks in advance for any help.
SampathS_11
250 sign-ins 250 solutions authored 5 questions asked
Hello @anne_4609456 ,
Kindly find the example file with power on function. We will send the example file with power off in a few days.
Sampath Selvaraj
Hello Sampath.
Thanks for send example code for PowerOn in cpp.
Anyway, I tried to compile and got an error (error c2065: 'hr': identifier not declared) in the code for PowerOn routine at line 365.
See attached.
Could you please help me to fix it?
Anselmo
Hello Sampath Selvaraj.
Did you have a chance to work on the PowerOff routine in C++ as wrote in your previous message?
Anselmo
Hello @SampathS_11
Anselmo
Hello @SampathS_11 ,
See attached.
Anselmo
