Is it me or does PSOC Creator 3.3 take significantly longer to open projects than version 3.2?
I tried opening the UART to BLE peripheral workspace in PSoC Creatore version 3.2 and it took 3 seconds. I was able to open several components within the workspace right away in different tabs.
Next I closed the workspace and opened the same in version 3.3 and it took 20 seconds and 2 seconds to open the main.c file.
Andres
Probably the time is used by checking for component updates. Did you try update of all components, a clean and build (I usually delete all generated sources first) closing Creator 3.3 and opening the project anew?
Bob
Bob
Uninstalled/Reinstalled - working fine.
